TwinTurbo.NET: Nissan 300ZX forum - Agreed. Starting to sound more like failing injectors. (n/m)
Stokens (AR)
on August 26, 2016 at 5:24 PM
How did you test the injectors? (n/m)
posted by -Grimm-
on August 26, 2016 at 01:36 PM
Z32 cylinder 1 & 2 dead
str86z
23:19:56 08/22/16
Re: Z32 cylinder 1 & 2 dead
Stokens (AR)
14:06:26 08/23/16
Re: Re: Z32 cylinder 1 & 2 dead
str86z
23:50:30 08/23/16
str86z
03:44:20 08/24/16
That is quite a bit of green stuff!
Stokens (AR)
16:42:32 08/24/16
you've done all the Easy Stuff.. Now lets hunt..
Cjw3
20:18:21 08/23/16
Maybe try visual verifying that the PTU wiring color codes
jzack
21:37:54 08/23/16
Re: Maybe try visual verifying that the PTU wiring color codes
str86z
00:03:54 08/24/16
Re: you've done all the Easy Stuff.. Now lets hunt..
str86z
23:57:55 08/23/16
Re: Re: you've done all the Easy Stuff.. Now lets hunt..
str86z
04:13:23 08/24/16
i would look into the corrosion issue as posted above,
itsa300zx
08:28:40 08/24/16
I would solder the subharness into the main harness
-Grimm-
09:47:31 08/24/16
Re: I would solder the subharness into the main harness
str86z
19:29:58 08/24/16
Depends on your test conditions, but yes
-Grimm-
09:45:18 08/25/16
Re: Depends on your test conditions, but yes
str86z
01:15:58 08/26/16
-Grimm-
13:36:23 08/26/16
Agreed. Starting to sound more like failing injectors. (n/m) -
Stokens (AR)
17:24:39 08/26/16
Re: Agreed. Starting to sound more like failing injectors.
str86z
19:02:43 08/26/16
Videos of my tests on cyl. 1 & 2
str86z
08:58:49 08/27/16
Re: Videos of my tests on cyl. 1 & 2
str86z
13:30:36 08/28/16
str86z
20:07:34 08/28/16
Hard to tell, maybe just the frame rate, but are they...
-Grimm-
13:48:58 08/29/16
Re: Hard to tell, maybe just the frame rate, but are they...
str86z
16:07:43 08/29/16
Start with checking the wire colors vs ECCS
-Grimm-
17:39:45 08/29/16
Re: Start with checking the wire colors vs ECCS
str86z
21:38:32 08/29/16
*VIDEO* Timing questions
str86z
21:44:33 08/31/16
str86z
03:04:25 09/02/16
Suggestions I am so close
str86z
00:32:41 09/03/16
str86z
04:19:57 09/06/16
